Ive been searching and searching thru these forums... ive probably found maybe 2 actual guides/instructions on how to convert vcds to dvd... but i want to get 3 vcds onto 1 dvd... they would obviously fit size wize... but ive been seeing things bout mpeg 2? alls i can seem to get out of all the instructions i follow is to come out with an mpeg1video with mpeg2 sound haha... i was hopin sum1 could give me or direct me to an easy to follow and not complicate guide to making this happen... i found sum guides with using 10 different progs... i dont think thats necessary... just tell me whut i need and how to do it... thnx guys
Shane
Need 2 programs;
VCDGear
TMPG Author
Use VCDGear to rip the DAT files to MPEG, and tell it to fix errors.
Now follow any of the TMPG Author guides. Basically your going to add the VCD's from file. TMPG will re-do the Audio to 48 Khz (I can't recall doing this manually). You decision is whether each VCD will be a seperate title or a segment of a single chapter (are they the same movie).
No re-encoding required, VCD is DVD complient (except for the audio).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
ya their the same movie... i just want to compile them to make one big movie... i have Sonic MyDVD to make the title menu and stuff (if it works) lol... but yes i want them all in one movie (i used mydvd b4 and it quit writing the movie half way.. dont know y)
Size of printed copy changing Why?
By orfajackson in forum Newbie / General discussionsReplies: 9Last Post: 11th Jun 2009, 20:45 -
Changing the shape/size of an mpeg
By cawright1 in forum Newbie / General discussionsReplies: 13Last Post: 9th Oct 2007, 14:28 -
Changing size of movie file
By SteveO.KanevO in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2007, 00:05 -
Changing the size of my Music Video's?
By GroovyGran in forum Newbie / General discussionsReplies: 8Last Post: 11th Sep 2007, 17:58 -
changing a videos size?
By curt1sw in forum EditingReplies: 5Last Post: 11th May 2007, 00:21
